Looking for some more low end.
  • TurboGTU
    replied
    plastic deal? you might be refering to the heater hose quick connector.
  • Purple pit
    replied
    That is the coolant by pass tube. The screw in kind is sold at auto parts stores. As for the push in style I have no idea.
  • Xkxbug04
    replied
    Any other advice on finishing this up? I've got the pushrods lengths already.
    What color thread locker for the bolts? Anyone have a torque sequence & specs please?
    Also broke a little plastic quick disconnect type deal. Connects at the thermostat housing and runs backwards. Was curious I if anyone had a part number for it?
  • Xkxbug04
    replied
    not bad, then again, i don't know what a fresh, stock 3100 will put out.
    Same here, my only reference is here.
    Just picked up manifold gaskets and oil and antifreeze & distiller water. Gonna get it together and see what happens. If I end up with another milkshake, then ill put it. Apart and grab head gaskets, clean up these heads slightly, shave em .015 to bump the compression a bit and get it back together.
    Main concerns for me are that it runs right and gains a bit of mileage. I know I know, 3400 this & that. NO MONEY for that stuff lol.
    replied
  • Xkxbug04
    replied
    These are how the compression test numbers came up...I'm not thinking its blown head gaskets at all?
    1: 172
    2: 160
    3:162
    4: 172
    5: 162
    6:156
  • TGP37
    replied
    You can always learn to tune the PCM yourself or get a dyno shop to tune your car. That is ONE way to get more power. Considering how far off your tune is, you could get very little to a whole lot more.
    If you have the 4t60e trans, an adjustable vacuum modulator thingy can increase line pressure and net you more grab n go from the trans. If you have the 4t65, you need to change PCM settings to achieve the same result.
    Then, if you decide to add some more like a cam or cold air intake, you can tune them in to get the most out of it. But do make sure your sensors, engine, etc is up to standard....no failing sensors while tuning.
  • Xkxbug04
    replied
    What's normal COLD compression for these cars? Compression as in on a pressure/compression test?
    replied
    Get another engine. Im not optimistic about the cam bearings or lifters. You really need to gothrough that motor
    I'll second that. The one time I didn't go through a good lim leak the cam bearings self destructed because of the coolant in the oil.
  • ericjon262
    replied
    3500 heads are better then 3400 heads in stock form, but IIRC, the chambers are too big for the 3100's. the AMC 6 is a tough cookie, dodge did a really dumb thing by doing away with it...
  • Xkxbug04
    replied
    interestingly enough, those appear to be 3500 heads in the picture...
    Awaiting contact from the seller, glad I posted as I'm 100% new to this motor or Chevys in general. I've just always had straight 6 jeeps. Still have my cherokee with a meaty 4.6l stroker built by myself. They are so extremely simple. This malibu was for the finances daily driver.
  • ericjon262
    replied
    Originally posted by Xkxbug04 View Post
    Work case I keep the bottoms end and do 3400 heads. I found a set on eBay for 300 shipped brand new ready to go.
    http://www.ebay.com/itm/3-4-3400-CHE...b19a6d&vxp=mtr
    Assuming all I'd need is a egr adapter & 3400 manifolds for this? Becsides gaskets of course. I've got 500 dollars to play with, including gaskets and fluids! Myself doing the work.
  • Xkxbug04
    replied
    Originally posted by geoffinbc View Post
    Its the intake gaskets just like the other million or so 3100 and 3400 engines that needed replacements. Finding a later 3400 in the junkyard to swap in is the cheapest way to go.
  • geoffinbc
    replied
  • Xkxbug04
    replied
    ^what he said these engines are too cheap to try and cob something back together that's had that much coolant run through the oil.
    Gonna go ahead and do a compression test in the am. If its good then ill replace the manifold gaskets & run cheap oil thorough it for a few hundred miles and change it out. Do it again if nessasary.
    If it wasnt smoking or anything I'm honestly guessing it was the manifold gaskets. We will see in the morning though.
