Twincam in a 2nd gen Phase I (2.8) Cavalier
  • inkycavz24
    • Dec 2004
    • 7
    Now before you flame me for being a newbie, I did search for the answer to this question. Can you swap a DOHC 3.4 into a Cav? Or would having overhead camshafts screw with programming?
    1988 Chevrolet Cavalier Z24-2.8liter V6 MPFI/5speed
  • RebelGT
    • 642
    simplest answer, no, the engine does not fit.
    26+6=1
    • v6h.o.
      • 1418
      programing are the least of your concerns... Exactly what RebelGT said.
      it *could* be made to fit. but then again you wouldnt have anything left in the engine bay compartment at all. Too wide.
      Colin
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        3400 it and call it a day. Your in the 14's and have a super reliable engine. Do some more work and do high 13's. All with a new engine from the year 2000 or above that will run like a champ.
          • 13520
          Id love to see an LQ1 in a J body...for the weight factor, but honestly it wouldn't be practical. Can you imagine doing the timing belt...hahaha! Pull the motor for that job. Id only consider it for a weekend racer and for someone with good fab skills.
          3400 leaves you with room for a turbo, and that pretty much takes care of the DOHC cause I dunno where the turbo would go...without even more fab work
          • TooManyCars
            • Dec 2004
            • 24
            It has been done.. http://www.geocities.com/jeremygonyou/3.4swap.html
            But as the writer of that page states Its a lot of work.. I have a 91 z24 in the shop and a good 3.4dohc siting on the shelf next to it .. I think I would rather make a go cart outa the 3.4 then squezze it in ther.
            91 cavaliver z24 5 spd,
            89&90 TGP auto
            90 olds toronado trofeo auto,
            86 GLX RX7 5 spd,
            85 nissan 300zx 5spd,
            84 dodge ram,
            http://www.kustomdreamzcc.zoomshare.com/
              • 13520
              It never was finsihed though, so I dont consider that done. Its close though, and shows the work needed. Too bad he used a 96 motor and made things much more difficult.
              • Quinky
                • May 2004
                • 159
                yeah but a 96 motor is a more fun for power..
                • Anonymous
                  The 15hp/tq, maybe less, isn't worth the extra pain of having to fuck with OBDII, and the additional wiring. Plus you are limited for exhaust manifolds if you do not want to run them factory style.
                  • Guest
                    Umm since when does the engine require a certain PCM?
                    I think it has been proven several times over now that the engine doesn'y care what PCM is connected to it, just that it controls fuel and spark reletivly well.
                    • TheProfessor
                      • 869
                      i saw an LQ1 in an older jbody once it just barely fit
                      although that was without a transmision under it
                      I Like V660s
                      Does Chevy make beer
                      ~Jayme~
                        • 13520
                        Its the EGR that fucked with jeremy. a 91-95 using MPFI would be easier to install in the J body for sure...not that it matters a whole lot.
                        • Guest
                          IBusingolderECMwiththenewerenginewouldwork
                          • Z2_4cams
                            • 147
                            that's mine
                            the problem is that the plenum wants to occupy the same space as the brake booster. so instead of removing the brake boost like Mr ganyou did. I'll be making a custom plenum*cough cough* with an m90 *cough* cough*. I will be using the same engine harness as the raven is for his hybrid. (even using the comp he was using for a bit )
                            1989 Z24 3.1/3400 hybrid
                            14.13@96.69 N/a slick full interior
                            maybe my \"dreams\" should be a little higher :P
