Cruise Control Switch Repair
  • Cruise Control Switch Repair
    It seems that ALL the cruise control stalks you find at the JY nowadays are non-working. The Cruise switch doesn't work. Tired of paying $40 for a new stalk, I decided to dismantle and attempt repairs to what I had.
    The stalk is glued together and there will be some minor cosmetic damage during the dis-assembly, but if you file down the burs before gluing it back together it is not serious.
    This is the stalk I am going to repair.
    First, separate it at the joint. I was able to grip a pair of wire stripper pliers into the joint and force the stalk apart. Slide out the switch by feeding the cable into the shaft.
    Pull off the outer end of the stalk housing. The SET button cap will pop out.
    Carefully slide out the OFF/ON R/A lever.
    The switch is held together by clips AND 4 plastic welded areas. I filed away the welded areas and carefully lifted the clips. You can see the dark discolored areas on the contacts.
    Cleaned the contacts on the housing, and bent the movable contacts up so they will have more pressure on the circuit board. Put a little bit of dielectric grease (NON HARDENING) on the slide.
    Snap the switch back together and insert it into the stalk housing. Carefully slide the cable through the shaft.
    At this time, it would be wise to make a functional test with ohm meter.
    Now, apply CA glue, carefully, to only this small area of the stalk.
    Assemble the end of the stalk and press HARD down to fix the end housing to the stalk.
    Should look like this. Snap the SET button cap onto the switch and that is the repair! You just saved $40.
    Hope this helps! Some day I will do a writeup on the cruise servo repair, for when the cruise will engage but loses speed.
    Thanks!
    David
      pocket-rocket commented
      Editing a comment
      You are full of good articles, it seems. Nice write up
    • davida1_hiwaay_net
      davida1_hiwaay_net commented
      Editing a comment
      Thanks for making this an article!
      bszopi commented
      Editing a comment
      Images now hosted on here. Click on the images to see the full size versions.
    Posting comments is disabled.
Article Tags
There are no tags yet.
Latest Articles
  • How to read turbo maps...
    by Driver_10
    There have been a couple of guys who wanted to know how to read a compressor map. Hopefully, I haven't made any mistakes this time (unlike the last) and this will prove to be useful to you in your understanding of a compressor map. Reading a turbo map isn't as difficult as it looks. The map displays 4 key pieces of information. A. It displays the pumping efficiency of the compressor (meaning the amount of actual air that it pumps in contrast to the amount of heat that's created while wasting e...
    11-27-2011, 10:01 PM
  • Tire/ wheel info
    by z34phoenix
    General Tire/Wheel info:
    Tire Calc: http://www.miata.net/garage/tirecalc.html
    Alt Tire Calc: http://www.1010tires.com/TireSizeCal...?action=submit
    Tire Info: http://www.discounttiredirect.com/di...foTireMath.jsp 5x115 The 1ST # is the number of lugs. The 2ND is the spacing between the lugs, measuring center point of the lug to the next lug. have heard that 5x114.3 from something like a mustage will work. Our wheels have an offset of +40. Offs...
    09-10-2011, 09:58 AM
    by davida1_hiwaay_net
    First, separate it at the join...
    07-21-2011, 10:09 PM
  • V5 A/C compressor tear down / re-seal...
    Pictures of tear down and re-seal of Harrison V5 air conditioning compressor. These are very common on the 60V6 engines. They are very costly as a re-manufactured unit. The parts to re-seal them are about $30. I did this write-up for another forum but figured it would have interest here. I started with this unit. I had it on my 1972 Chevy Nova until it started leaking around the housing o-rings. It still cooled fine, it would just lose freon over about a 2 month period. It will go on a 2.8 car...
    07-17-2011, 08:47 AM
  • WOT-Tech pistons and the CR Calculator
    by bszopi
    With all of the different top-end swaps and bottom-end builds out there, I was talking to Ben at WOT-Tech about the Diamond pistons and how different setups would affect the compression ratios (CR) of the pistons he was offering. I wanted to pass this piston information on to the users so that they could then determine what their final CR would be with any setup. Due to marginal sales, WOT-Tech has decided to no longer list or stock specific CR pistons anymore. What does this mean to everyone? It means you can tailor the pistons to suit your specific application, no matter what components you are using. ...
    01-24-2011, 02:21 PM
  • How to Re-New Your Cracked Dashboard
    by 60dgrzbelow0
    I searched the forum for any postings on this subject and drew a blank. Although this fix is related to any F-Body, I wanted to share it as a possible solution for anyone replacing their dried, crusty or shattered stock dashboard cover with a durable new cover and one that includes an inexpensive way to solve the lack of vent covers that most of these covers present with. Here is what you will need to do the job correctly and fast, too....: To avoid "a thousand words" that follow... here are th...
    01-01-2011, 10:06 PM
