4T65E
  • Mounts
  • 4T65E and 4T65E HD (99+) N-Body Swap
    Mounts:
    Now that you have the transmission it is time to get it mounted. There are 3 mounts that will need to be addressed; the front, side and rear. Below are pictures of the different routes that may be taken.
    GM Concept Mounts:
    This route will require the most fabrication.
    Front Mount:
    1. Production Mount
    2. Adapter Plate
    Side Mount:
    1. Production N-Body Side Mount, trimmed and welded to fit the 4T65E HD
    Rear Mount:
    1. Stud with spacer in existing 4T65 HD mounting hole.
    2. Two 10mm X 1.5mm bolts in existing 4T65 HD mounting holes.
    3. Production rubber mount from 98 GA manual transmission application.
    4. Custom pencil brace to existing transmission mounting hole.
    Milzy Motorsports 4T65E HD Conversion Mounts:
    Milzy Motorsports offers all 3 mounts for a price of $450.00, by far the easiest option however it is also the most costly option. It is important to note that the rear mount (pictured far left) is specific to the 4T65E HD transmission and will not work on a 4T65E transmission case.
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
    • 4 Speed Automatic Transaxle Info
      robertisaar
      by robertisaar
      The following pages contain information on specific transmission models from the 4T60, 4T60E and 4T65 family(4T40/4T45 and 4T80 information may be in the works, stay tuned). For now, it is NOT an all-inclusive list, but any missing information would be appreciated. Miscellania: 4T60E Differentials with an asterisk are "fine pitch" final drives. Sun gears, internal ring gears, and pinion gears are NOT interchangeable with other final drives. 4T65E with "IMS" have the newer type of s...
      10-08-2010, 02:48 PM
      by onefastV6
      So you have significantly modded your engine and now your transmission seems to be the weak link of your build. You have a few options to upgrade the stock 4T45E transmission which can be rather costly, or you can swap to the stronger 4T65E series transmission which seems to be uncharted territory for many. The purpose of this article is to provide a little more insight on what it will take to swap a 4T65E transmission into your 99+ N-body. ...
      09-20-2010, 09:36 PM
    • 4T4x-E Mechanical Specifications Information
      bszopi
      by bszopi
      4T40-E/4T45-E Automatic Transaxle Unit Repair
      NOTE: Click on images to see a full-size view.
      Fastener Tightening Specifications
      End Play Specifications
      Reverse Clutch Backing Plate Specifications
      On-Vehicle
      General Specifications
      Range Reference
      Shift Solenoid Va...
      08-18-2010, 09:25 PM
    • 4T65E Hardened 4th hub and solenoid upgrade
      Tbay99Venture
      Push-starting the old way
      by Tbay99Venture
      INTRO This is a guide on how to service your transverse automatic transmission without a lift. All work is done with the vehicle on jack stands. Once the cover is removed the valve body is left attached to the channel plate. This assembly can then be moved to a workbench for easier servicing if valve body work is in your plans. In any case the transmission drive chain, pump, 4th gear assembly and many other parts can be repaired or upgraded at this time. In the description below the term "c...
      07-24-2010, 10:59 PM
