CBX POWERKOTE (Cermet Coating Thermal barrier)
Designed for Performance engines running; Nitrous oxide, Supercharged or Turbocharged. For all other applications use CBC2. Creates a hard surface specifically designed for engines running High volumes of fuel and/or high compression ratios.
- Thermal barrier coating.
- Reduces part temperature. Keeps heat in combustion chamber longer through the power stroke.
- Increase torque and H.P. Increase combustion chamber efficiency.
- Reduce fuel consumption.
