Hello all.
I think 'I've been dormant for more than a year now. Some of you may remember me. - I'm the guy who sold the full set of new internals for an HM284 a couple of years ago. I had acquired them from Getrag Gears in NC shortly before they scrapped the parts they had left. Coy (one of the rebuilders that worked on the transaxles when GM still had their dealer rebuild / exchange program ) told me that they scrapped enough parts (management told them "to make room") to rebuild a couple of transaxles. Great! 'Way to treat such rare parts (trying to swallow puke)! It sticks in my mind that the purchaser was a member of this group. If so, shoot me a message and let me know what you ended up doing with them.
I've finally commited to building a stroker LQ1. I've been half-heartedly acquiring parts for several years now. In all honesty, I'm not adding much stroke. Just enough to allow the use of off-the-shelf parts. The reciprocating assembly is a hybrid combination of an offset ground 3500 steel crank, 5.850" modular Ford stroker rods and '93-'99 NorthStar slugs with floating pins. Final stroke will be determined after the block is machined and I have the new rods to mock up with the stock crank. Preliminarily, I have estimated displacement to be around 3.6L. I say preliminarily because I am not sure where the stroke will end up after the block is squared and calculations are made for optimum quench. It looks like the stroke is going to wind up being around 3.44" The donor engine is an 80k mile unit out of a rolled '96 Z-34.
Necessarily, with the stroke and compression, I am planning on an N/A build. I am going to have Joe Bray at American Custom Cams analyze and regrind the cams once I have a definite figure on compression. Speaking of compression, unless I do some modification to the combustion chambers, the bore / stroke combination is going to yield around 11.2:1. It might make sense to use a pair of earlier heads to get around this. I really don't want much over 10.5:1. At the same time, dont want to give up stroke or sacrifice optimum squish / quench. I guess I'll get the block machined and then address the challenge when I know what I'm dealing with.
Once the cams are ground and I have an idea of powerband, I will be able to calculate optimum intake runner length / volume for ram effect timing. This will allow me to build a performance matched upper intake.
Lastly, I plan on making a set of 180 degree anti-reversion headers. AR cones almost seem redundant on a 180 degree design but I have been aching to make a set of AR headers since first learning about the design theory. I've had a set of '96-'97 flanges for about 3 years now and they are just begging to be used.
The vehicle this is going into is a 1996 Z-24. I was fortunate enough to land one of the surplus 3.94 fdr NVG transaxles that have been floating about. I need to get the case half swapped for use with the LQ1. Right now it is setup for a Quad-4.
This is a winter project so it'll be a little while before I get rolling on it. Right now I am trying to finish up work on my M35A2C so that I can get it sold.
Feel free to add comments / questions. I hesitated making the post because I understand the disproportionate ratio of theory / daydream and accomplishment when it comes to things like this. In spite of that, I thought some of you might enjoy hearing about my project. Fortunately for me, I own a decent assortment of full-sized conventional machinery to make such things possible.
~Cheers
~Cheers
