WTB Custom grind cam RWD
  • WTB Custom grind cam RWD
    I have 3.4L RWD and I have a few numbers for a cam, I need someone who can make if for me if possible.
    1988 Firebird
    3.4 60*V6
    9 Bolt Rear, 3.27:1, Disk brakes
    Edelbrock 3790 Cam & Lifters
    COMP Cams Magnum Steel Roller Tip Rocker Arms 1414-12
    COMP Cams High Energy Pushrods 7816-12
    COMP Cams Valve Springs 980-12
    PaceSetter Headers 70-1206
    Shoot me the specs you are looking at to john@60inclusive.com and let's see what you got
    Here's one of our most popular grinds...
      Do you need the cam sensor for SFI operation? 88 camaro wont use it unless you swapped to the DIS with the 3.4 engine. what numbers do you have?
        I dont need a cam sensor stuff or anything. I have the specs of:
        * Duration (Intake/Exhaust): 226°/236° @ .050"
        * Valve Lift (w/1.5 Rocker): .463"/.474"
        * Lobe Sep. Angle: 112°
        1988 Firebird
        3.4 60*V6
          bump I emailed you ForcedFirebird
          1988 Firebird
          3.4 60*V6
            bump
            1988 Firebird
            3.4 60*V6
              bump
              1988 Firebird
              3.4 60*V6
                Sorry man, gotts remind me, we have 100 things going on at the shop right now
                Actually let me jump on dynomation now and get right back to ya...
                  We have that grind. Did you need new lifters with it, or you buying them yourself?
                    Stand in line buddy. Ive got stuff commin myself.
