I have gotten my 3.1L in my 90 cavalier running on $8D code. This opens up 16 BLM cells instead of the $A1's 3 cells, also the support for TTS Datamaster 8D and a few other 8D specific stuff.
I have a zip of the stuff I did.
Includes a AUJP1350 bin from a 91 TPI 350 camaro, a new XDF file for TunerPro with the needed constants added, and a sample of the bin I have been testing in my car.
change Spark Advance Initial from 5.98 TPI to 59.77 for DIS ignition v6
change Spark Advance Max from 41.84 TPI to -9.84 for DIS
change Spark Retard Max from -3.87 TPI to -69.96 for DIS
other stuff will need changed, like number of cylinders, injector size, cylinder volume, as well as VE table and Spark Tables.
good luck.
I have had mine running, but a few bugs to work out. AC on my car is controled by ECM, 8D does not do it. Also I'm not getting a speed input from the speed sensor.
good luck.
