any interest in solid engine mounts
  • any interest in solid engine mounts
    thinking about having a set made. any else want a set while i am at it???
    Are you talking tranny mount as well or just the two pass. side lower ones?
      i was thinking all 3 lower ones. i have heard some peeps say the vidration isn't that bad....one way to find out.
      if nothing else i will probably run that front lower one for sure as it always shows the most wear of the 3.
      1 more thing i am running a 284 so my driver's side mount may be different depending on what kind of tranny you are running.
      what material you want? i will probably go aluminum but one machinist i deal with has this type of delron that is almost as hard as aluminum. i will have to consult him on it's actual strength. machining delron should be cheap as hell.
        I have a 284 as well. It may not be something I'd be interested ATM, depends on the price. All my mounts are only 3 yaers old and have maybe 25K on them so they're still pretty stiff.
          What does a set cost?
          I'd be putting it on my auto though.
          1991 Grand Prix STE
          3.4 DOHC
          1 of 792 Produced
          Extensive Mods Done
          1991 Lumina Z34
          3.4 DOHC
          Getrag 284 5spd
          1 of 30
            don't have a clue yet. it was a descision on a whim i made today. i need to call around as any machinist can complete this job and i will be going for cheap instead of prescision.
