OK, here is a list of known problems with my neighbor's '95 Grand Prix / Auto
1. It keeps blowing the IGN2 fuse (40A) which also causes the power windows to stop working... this is in the pannel on the drivers side of the engine bay.
2. When you accellerate from a stop it feels like it's starting off in 3rd gear, you can manually move the shifter into 1st and it goes in fine.. manual shifting works great. (Possibly related to the IGN2 fuse blown?) Yes, i checked the "2nd gear start" switch as well, it's off.
3. Oil pump shaft is leaking (go figure) also appears to have a coolant leak in the same area, haven't figured out where it's coming from yet.
4. VERY poor performance, He had the timing set over a year ago and he said since then it's been a dog. I drove the car around the block and my 3.1 cavalier has more power... Possible that the cam timing has been set wrong?
5. Surging idle (i think an idle re-learn might fix that) he said it's been doing that since the timing was set..
6. A mystery plug in the engine bay.. it's a 2 pin Black/Orange. Looks like the CTS plug for a 3x00 but it's just curled around and stuck down next to where the fuel pump test circuit is. Can't figure out where it goes...
Short list.. there is more wrong with the car but this is the major stuff. If anyone has any input it would be much appreciated. He's going to take it to the Zone and get the trouble codes pulled tomorrow, i'll post the results.
Thanks,
Dave
Thanks,
Dave
