Hi,
I have a 1993 Cutlass with a 3.4 DOHC. Last May, I had the 185,000 engine replaced with a GM replacement 3.4 DOHC crate motor I found.
Yesterday, the engine just stopped while driving. After I had it towed home, I found the DIS 10 amp fuse blown. I changed the fuse and it blew again, so I figure I have a short in the wire or in the spark module itself.
About 6 months before I had the motor changed, I had to replace the spark module and recall it was not an easy task since for 1993 the coil packs and spark module are on the side of the engine beneath the exhaust manifold.
Has anyone moved the spark module and coil packs to the top of the engine somewhere like I think the '96 3.4 had?
If so, how did you do it, how long does it take, how much does it cost, and was it worth it?
Thanks
Scott
Thanks
Scott
