ok i have not checked yet but tomm. i am, i think i may have switched the 135 injectors connectors witht he 246, would the car run? i am expeirienceing a small backfire in shift, flames at shift and poor fuel economy?> is there a way to kno which are for the fron bank and which are for the rear?
injector wiring harness
The front injector wires only have connections for the injectors, the rears have hookup for the EGR, TPS, and IAC. How are your plugs/wires? Reason I ask is flames usually indicate alot of raw fuel passing through the exhaust.-60v6's 2nd Jon M.
You might have a stuck injector. Or maybe you have a coil pack going bad. Possibly your timing might be of.-60v6's 2nd Jon M.
