I found the cam specs, but I'm unsure how to read them.
I can easily see the max lift and what that means. However, what I am unable to understand is at what point the Valves are opening and at what point they are seated again.
Lobe Lift (Intake)
0.370 @ 108° Crank ATDC
Lobe Lift (Exhaust)
0.370 @ 115° Crank BTDC
Timing Reference Set Position with Camshaft Timing Flats in Clamped Position-Right Bank
TDC-1Piston Exhaust Stroke +/- 2° of Crankshaft
Timing Reference Set Position with Camshaft Timing Flats in Clamped Position-Left Bank
TDC-4 Piston Exhaust Stroke +/- 2° of Crankshaft
Lobe Lift (Exhaust)
