ive found out that the honda civic cold air intake that you can get at any autozone for around $40 will fit our cars perfectly if you cut about 3 inches off the end. they are in a orange package and have sone stupid writing on it. i got mine off a friend for $5 including air filter. ill post pics if anyones intrested.
cheap cold air intake
91 GTP HM-284 GONE
96 Special Edition LQ1/4T60E GONE
98 Spawn of Satan (L67 Regal)
87 V10 SM-465/Mild 350
06 Cobalt SS/SC GONE
heres some pics. i know its not a real cold air intake but its better tham stock and sounds much better. im gonna try and build a heat shield to keep it cool. if the pics dont work ill try again, im not quite sure how to post pics
[img]C:\Documents and Settings\Administrator\My Documents\My Pictures\My Ride\dsc182[/img]
[img]C:\Documents and Settings\Administrator\My Documents\My Pictures\My Ride\dsc183[/img]
[img]C:\Documents and Settings\Administrator\My Documents\My Pictures\My Ride\dsc185[/img]92 Lumina euro 3.4 DOHC 139,XXX miles
All and all, how long did it take you to remove the stock box and replace with the new intake? I am thinking about doing this but am not very mechanicaly inclined. Do you have to drill any holes or anything of that sort. And will it increase any performance on a stock car.Thanks.
Kyle
P.S. Is that a Lumina Z34 in the pics?1992 Lumina Z34
5 Speed
Autozone civic intake
Ultra White lights
FFP Dogbone mount
125k miles
2.5 inch Magnaflow catback from Magnaflow cat
60degreeV6.com Custom Chip
it'll take 30-45 min. to do. you have to cut about 3-4 inches off the long end and drill a hole for the Intake Air Temp. sensor. fairly stright forward. seems to give mabey 5-8 seat of pants HP. also give it a real good sound under acceleration.
And its a 92 EURO 3.492 Lumina euro 3.4 DOHC 139,XXX miles
its the sensor on the back driver side of the origonal air box. i put on the bottom of the tube near the filter. and like i said before i know its not a true cold air intake but im going to build a heat sheild along the bottom and engine side to keep it cooler. there are also other things to keep in mind. like the less restriction, and less turbulance. still a fairly good upgrade for the price. look one up on www.rsmracing.com big price difference for basically the same thing.92 Lumina euro 3.4 DOHC 139,XXX miles
