Unless this is somewhere else on the site, and I'm just not seeing, I think we need a sticky thread to put in GM part numbers. I need the part number for the DOHC Top Engine Gasket kit if anyone has it. Then let's keep adding in numbers as we come across them, and I'll categorize them and update this thread as needed.
GM Part Numbers Thread
RE: GM Part Numbers Thread
not sure if you want these suspension parts but
12498649 GMPP tubular trailing arms
12498648 Buick strut tower braces
10259660 7/8" sway bar bracket (rear inner)
10270253 7/8" sway bar bushing (rear inner}91 GTP HM-284 GONE
96 Special Edition LQ1/4T60E GONE
98 Spawn of Satan (L67 Regal)
87 V10 SM-465/Mild 350
06 Cobalt SS/SC GONE
Here's a few from a write up: 96 Intake Swap on to a 91-95 3.4 DOHC : Version 1.20 (4/5/2005)
12538693 - 96 Intake gasket kit. Go to the dealer for this one. Every parts store I went to wanted $95 and they did not have it in stock. My local dealer had it in stock and I purchased it for around $30.
24505533 - Crankcase valley to PCV Valve Line. This is a metal line with rubber elbows, and it is not cheap. If you had a complete donor motor, get the one off of there if you can, otherwise it will cost you around $45 at the dealer, cheaper on GMPartsDirect, of course.
24505440 - Valve Cover to Intake Pipe Hose. This is a cheap one. Just get it new from the dealer.
24505273 - Canister purge sensor to Intake Pipe/Canister Purge Vent to Intake Pipe Combo. I think $6.00, not too bad.
10283991 - Brake Booster Hose. This one is radically different, twice as long with a lot of new bends, and it connects to the top of the intake pipe.
24505575 - Fuel Pressure Regulator Hose. Again, cheap. Get a new one from the dealer.
24504034 - Intake pipe to Plenum Gasket. This one costs $2.00 and its worth replacing right now because it gives you a good chance to clean the pipe, clean out the entry to the plenum, and have a good seal there.
24504035 - Throttle Body to Intake Pipe Gasket. It costs $1.61, and again, worth doing and it gives you a chance to clean out the TB really well.
I'll add these:
24504025 - Upper intake manifold to lower intake manifold gasket 96-97 $2:00
10223366 - Cam carrier gasket $38.22 list
10464067 - Delco rem Alternator $195.17 list $139.61 wholesale 95-? Z34 Monte Carlo
24505203 - Serpentine belt $53.59 list $ 39.51 wholesale 95-? Z34 Monte Carlo
24202835 - 4T60E Trans RH Halfshaft seal (RH axle output seal) $5.95
89017530 - Fuel Pressure Regulator or FPR for short. $67.63 list $47.34 wholesale 96-97 Z34 Monte Carlo
01997210 - EVAP purge valve solinoid. $27.76 list $19.43 wholesale ?-97 Z34 Monte Carlo
8995284 - PCV valve $4.06 ?-97 Z34 Monte Carlo
10162177 - LH or front valve cover gasket $7.26 ?-97 Z34. (this one has the notch in it to clear cam position sensor)
24504412 - Spark plug hole seals for valve cover. 3 required per side $3.30
10233200 - Upper rad hose $18.70 ?-97 Z34
24507270 - Serpentine belt tensioner $63.28 list $48.46 wholesale ?-97 Z34
25537068 - O-ring seal for coolant pipe between intake arm and intake manifold 2 required $0.69 96-97 Z34
26064188 - High pressure P/S hose $83.71 list $62.78 Wholesale ?-97 Z34
17997163 - Front strut insulator for top of strut. Under 3 hole plate on top fenderwheel ?-97 W body
these numbers im not 100% positive what they are.
17113544 - (i think it is ) Injector and fuel rail reseal kit $22.03 list $15.42 wholesale ?-97 Z34
17113199 - Seal-fuel Fuel rail seal kit? ?-97 Z34
24504709 - Seal $0.67 (I think it is the o-ring seal for the steel waterpump bypass hose were it go's into the intake manifold)1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
Re: GM Part Numbers Thread
You talking like a headgasket set? That sucker is pricey! like 400.00 bucksOriginally posted by OldSkoolGPUnless this is somewhere else on the site, and I'm just not seeing, I think we need a sticky thread to put in GM part numbers. I need the part number for the DOHC Top Engine Gasket kit if anyone has it. Then let's keep adding in numbers as we come across them, and I'll categorize them and update this thread as needed.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
Ya its not bad at all on GMPD. Shipping seems high. But all together its cheaper then the dealer.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
Its started, but I don't have time right now to finish adding all of the PNs that are currently listed in this thread. When you want to add new PNs, add them to the comments section of the article and I will update the table to reflect it.-Brad-
Another DOHC part #
010127488 Cylinder Head Gasket 1997-?? 3.4 LQ1 $35.55 list
$26.64 Wholesale1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
not sure if i should put these here, but here are some 284 part numbers
14082039 - detent holder cover
14092900 - axle seals (discontinued)91 GTP HM-284 GONE
