In the very near future I plan to build my own cold air intake, originally planned to be a fenderwell intake, I don't want to move my battery so I am seeking other options. So today I pulled the entire assembly and tried to figure something out that would work for me. While doing this I came up with a number of questions. I don't expect any one person to have all the answers, but I'm hoping that the combined knowledge of this forum can give me a better understanding of what I'm up against.
I've taken some pics to better assist me in describing my questions.
1. Is this the MAF screan I have heard about people removing? And what are the risks/advantages of doing so?
2. Just after the MAF assembly there is another sensor in the ducts, what is this and what will happen if I move it?
3. Along with the plug for the MAF and that other sensor, there is also this plug coming out of the same wiring harness, however it was not attached to anything. Any clue what it is or where it belongs?
4. Just before the TB there is what looks to me like a vaccuum line. Is this what I think it is, and do I have to keep it there when I make the new intake?
5. My new idea, rather than moving the battery, is to run a new intake pipe through the rad support and go behind the headlights. The only road block I seem to hit is this hole is not big enough. My guess is its a bad idea to widen the hole for a 3 or 4 inch pipe to go through...no? Another option could be to go to a drier duct to get through that hole, provinding there are no kinks in it, the area of the hole should remain the same
Just playing around I got a couple chip containers and chopped them up, although a little smaller than I would like to use, something like this may work. the advantage of the drier duct would be I could use the entire space of the hole, this little mock up only uses about half of it, a little less than the stock airbox snout lets through.
6. Aside from this and keeping the MAF sensor in the same general place, is there anything else I should keep in mind while building this thing. I will most likely also be adapting this idea to a friends 92 GP 3.1L.
The place I have chosen for the filter (just under the headlights) does not seem to get much splashing of water, as we just finished with winter here and you can see where the splashing goes for the most part by the mud and salt stains on the back side of the bumper.
Thanx, any help would be greatly apprieciated
Jamie
Jamie
