Ok here's the deal 1994 Pontiac Grand Prix GTP 3.4 DOHC Auto trans. about 130K miles on it now.
Here is the issue: When cold, it starts right up idles fine. as soon as its warm the idle just goes up and down from like 400rpm to 1400 and eventually stalls when it drops to low. Been driving it like this for a good 7-8 months--double pedal--to keep it from stalling. When driving it runs fine, gets up to highway speeds with no issues. However when parked, if I get the idle up it starts to skip around 4000rpm.
So far we've replace the idle air control module, plugs, wires, injection cleaner with no results but maybe a bit smoother running. Killed the battery to clear the computer.
Mind you that no check engine lights are on. plugged into a computer a while back it said the O2 sensor might be bad.
Has anyone experienced this issue?
Here are some past suggestions
-Overdue timing belt change
-mass air flow sensor
-leaking intake gaskets--haven't tested for that yet
Any help would be great!
Thanks
email me at mindstrap@gmail.com
Mike
Thanks
Mike
