My question is if I have an interference motor and if I do or dont would the motor lunch when the belt snaps. I own a 1995 Luminia LS 3.4  engine vin code x. Really need help with this dont know if I should replace the belt or motor thanks.
Timing Belt Snapped
 the older ones are non-interference and from everything i know the 96s and 97s arent either unless the heads are shaved too much or something, even though a lot of service manuals say they are.91 GTP HM-284 GONE
 96 Special Edition LQ1/4T60E GONE
 98 Spawn of Satan (L67 Regal)
 87 V10 SM-465/Mild 350
 06 Cobalt SS/SC GONE
 i've heard of early LQ1s smashing valves, from what i understand a lot of it has to do with what was going on when it broke, like when mine broke i was just a little over 2000rpm, but at about 6000rpm you have a higher chance of something getting smashed, but personally i'd replace the belt and you ought to be fine from there.-Chris
 1992 Chevrolet Lumina Z34 3.4L TDC Getrag 284
 1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
 1997 Pontiac Bonneville SSE 3.8L v6, Hydramatic 4T60E
 1987 Chevrolet Camaro 5.0L v8, Hydramatic 700R4
 Make sure it isn't the distributor o-ring leaking. If it is the o-ring leaking you'll have to pull the rear head to do it right to replace the o-ring. Most people hack it and RTV the mating surfaces and cross there fingers.Lifting my front wheels, one jack at a time.
