I just changed out my intake gaskets on my 92 z34 got it all back together and I had a gas leak coming from my fuel rail. I took the plenum back off and turned the key to turn on the fuel pump and gas is coming out of the bleeder/nipple? but I need to know if this is something I can fix or if I need to find a new fuel rail any help is much appreciated as I'm trying to get to work on Monday.
leaking fuel rail
should be able to fix it by replacing the schrader valve in the fitting. The ones from a tire repair vavle stemm kit should work but I could be mistaken. I know the tool will remove it.Lorenzo
Yea a few people I talked to said to try that, I've never taken a valve stem out before nor do I have the tool. I just went to the junk yard though and got me another rail, hopefully this one works fine. Thanks for the help, hopefully I can get this whore back on the road today
i would try replacing the the valve first it will only take a sec, its as easy as un screwing a screw man dont go through all that head ache again riping off the intakes1997 Chevrolet Camaro 30th Anniversary 5Speed.
3800 V6 (i know its not a 60degree)
stock for now
1993 Special Edtion/GTP
3.4 DOHC V6 LQ1 SOLD!
CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230
I already had it apart anyway, plus I f-ed up my lower by over tightening the coolant outlet nut, or whatever it's called. Luckily I picked up another lower while I was at the junk yard, but I broke the egr tube and stripped the head off the one at the junk yard so that's gonna cost me $80 from the dealership. maybe some day I'll be able to drive it again. At least it doesn't leak gas anymore, and my egr tube looked like it has been kinda f-ed up for a while now. So whenever I get it back together it should run like a champ, especially cause I'm gonna drive the hell out of it when it gets back together.
