engine idle is at 1500rpm What would cause this:
Idle problems
First off, why the second post?!?!
Could be several things. Is this even when its warm, or just when its first started and the engine is cold? First thing you need to do is check for vacuum leaks. Get some starter spray and start spraying around gaskets, vacuum tubes and such. If the engine surges, then you've found the area of the leak.-Brad-
