I got one in my conversion kit. I feel its better to do it while the engines out and before it goes bad. How do you change it? Do I have to pull the cap?
How to do a rear main seal?
Question : How to do a rear main seal?
-White 1995 Pontiac Grand Prix GTP - 97 207DOHC/6SPD MTX +Tags: None
no you dont have to pull the cap.. If you dont have a seal puller just be careful with a screwdriver and dont nick up the crank. Pry it out and put the new one in.. Dont forget grease.. It's just like changing any other seal basically..Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors
White
3" Magnaflow Catback
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built car
i use grease on the inside of the seal so it sllides in real nice and doesnt tear or damage it plus it helps lube it.. when i did my rear main i didnt use any rtv but it wouldn't hurt to put it on the outside of the seal for extra protection..Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
Actually, I just did my rear main and used oil on the seal.... Later on I found a GM Service Bulletin on the new seal and they said use NO oil or grease to install, keep it dry... I can't see a problem with lubing it and I hope it holds!!! I'll find the file and post it....
TomAttached FilesLast edited by walterdude; 07-15-2008, 11:30 PM.
if the engine is nice and old then you should pull the cap and re RTV the cap and the block mating surface.Then you can replace the seal at that time. Otherwise just pull the seal and repalce it.Lorenzo
