I understand that the 3.4 fuel injectors have a unique spray pattern; I'm wondering if they have any tendency to clog or otherwise foul.
My Luminas run ok; at 120K and 140K they're probably down on power from when they were new--but not a lot. They are getting harder to start when cold, though. While that may be battery related more than fuel related; I do begin to wonder if a proper fuel injection cleaning is in order.
1. Have any of you had a REAL injector cleaning service performed;
2. Did it "fix" a problem or just lighten your wallet; and
3. Do you know what procedure was followed?
4. Any of you do injection cleaning professionally? Tips or recommendations???
Specifically, I'm after more than just "dumping ten ounces of schlubba in the gas tank and driving around"--unless--doing that made some major difference in the way your vehicle ran.
I'm expecting that a proper cleaning will use professional-grade solvent applied to the fuel rail while the fuel pump is disconnected or bypassed. Do you know what brand of solvent was used; and who made the equipment to perform the service?
I'm looking primarily at the OTC equipment; I think I can buy the tools outright for about the same cost as having my three high-mileage vehicles cleaned at a shop if I'm able to fabricate a few adapters.
