Noticed it on the way to work this morning... slowed down to about 50 on the highway in 5th gear due to traffic and when I gave it some gas to get back up to speed it was misfiring enough to feel it skipping and obviously lacking in power. Off the highway does it under heavy load as well (basically if you lug the engine at all). At higher rpm with a good bit of throttle it seems to not misfire at all and the idle seems fine as well. Mostly venting at this point - I'm getting a bit tired of the gremlins that come with an 18yr old car. Right now I'm assuming its an ignition issue and hoping its nothing more than a coil or the ICM since I have ample spares of both. I don't think it is the CPS or wiring since both of those items have been recently replaced.
I have had both the CPS and CPS wiring fail on me in the past. When that happens the source of the problem is obviuous since it loses the tach signal and you can visually see the tach spiking up/down with the intermittent signal. Tach was steady this morning so I'm assuming CPS/wiring are good. OBD I seems oblivious to the problem, no SES.
