This Grand Prix has given me a bit of trouble in recent weeks........orginally, the car would run until it reached operating temp, then die....no spark. Turns out the crank sensor had a minor crack in it and from the expansion due to heat was enough to cause the signal to die...killing the car. Replaced the sensor (had to remove pan to remove sensor....that was fun)....car started fine....ran for 20 min or so....ran great. Shut it off, cleaned up......tried starting again... no go.
I have spark....I checked the front three cylinders (which checks all three coil packs)....just fine. I have fuel pressure at the fuel rail....I pressed the test port with a screw driver....all kinds. This proves the crank sensor, ignition module, coil packs, wiring, pcm, fuel pump, and fuel filter are ok....at least I think so....would you agree?
I removed a plug.....wet as hell...in fact, the three front plugs are all wet. I let them dry out.....still no firing happening....I still have spark and fuel pressure though.............what IS the proper spec and testing procedure?
I ohm tested the injectors........mind you, I have no idea what the proper spec is.....but I measured them at 4 ohm, 14 ohm, and 13 ohm.......this is with a cheasy Craftsman voltmeter.....not a fluke, but should be good enough.
So it seems as if I am getting to much fuel to the cylinders..........this could be cause by bad injectors, bad harness, bad pcm, or a bad fuel pressure regulator......at least in my train of thought.
Any ideas?
Any ideas?
