What kind of grease goes under the ignition module? Dielectric tune-up grease (the kind you put inside the spark plug boot, or some other kind of grease, like white lithium or engine assembly lube? (yes, I'm being serious.) Also, on my 3.4 there is a metal plate between my engine block and the actual module, same size as the module. My buddy's 3.1 didn't have one. Is that some kind of heat sink or something?
I got one from the J/Y and didn't use any grease of any kind, now when it's damp outside, I get an arcing noise coming from the direction of the coil packs.
thanks...
thanks...
