OK, so the car has been starting hard for a while now. Sometimes it fires right up, other times (became more frequent) it will not even crank.... I turn the key, all the lights go off and the radio memory wipes out. After about 3-5 attmepts (turn key a few times) it will finally will start.
NOW i just replaced the starter and it fired up like 8x in a row. pulled it out of the shop and now nothing, key turns makes a single TICK noise and nothing... 3 or so attempts later it fires up.... Whats next? Battery? bad starter out of the box? the starter did sound a little funny on the disengage (like it was not pulling out fast enough when the engine started)...
MAY OR MAY NOT be related but some times my dash is a little dim and then i hear a click like a relay and it gets brighter, when its dim the needles "Twitch" when the blinker is on.... If that makes sence?
Thanks for the help.
S
S
