I have a 1995 Oldsmobile Cutlass Supreme with a 3.4 DOHC with 152,000 miles on it. I have to add coolant about twice a month. When I bought the car, it had green coolant in it, so that's what I’ve been adding. The coolant looks good in the radiator, no gunk that I can see. There is also a significant oil leak coming from somewhere. I plan to investigate that shortly. I've thought about the lower intake manifold gasket leaking, but the engine idles fine with no issues other than a slight stumble from a stop light. I'm guessing that's because I need to replace the throttle position sensor. Any Ideas of what I need to do from here?
Thanks!
Thanks!
