'93 Lumina Euro 3.4 (DOHC)
Will be removing rear head to inspect coolant loss into #2 cylinder; and pressurized cooling system (combustion gas into water jacket.)
I intend to install a block heater while the head is off and I have access to the core plug. I'll install a fresh oil pump drive O-ring and distributor gasket. I expect the O2 sensor is poisoned. Will investigate the catalytic converter--I think it's broken internally and rattling. Will clean the plenum and EGR passages, and clean/test the EGR valve. Will ohm-test the injectors. (Engine ran pretty good until the cooling system filled with air and the engine overheated.) [EDIT]Timing belt has only 25K on it; it looks good, I'll re-use it. Leakdown test shows good cylinder sealing except for bubbles into the water jacket for #2. [/EDIT]
I intend to investigate the "cold knock" oil system TSB. The kits are not available any more, but it may be that I can find parts separately. Since the cams have to be drilled, now would be the perfect time to dick with this.
My questions are:
1. Are the head bolts re-usable? Service manual says to clean the bolts (does not say to replace them.)
[EDIT] Yes, bolts are re-usable unless visibly stretched or otherwise damaged. The "safe" thing to do is replace them. I did not.
2. Does the 3.4 engine have a history of warped or cracked heads/warped or cracked blocks? I'm really hoping this is a head gasket problem. Won't know for sure until it's apart.
[EDIT] I had to shave the heads .015 to clean-up low spot where head gasket popped. I believe the heads have a weak area that "collapses" and reduces the crush on the head gasket fire-ring. Then the gasket fire-ring squeezes out from under the collapsed section of the head. I am HOPING that this is a once-and-done deal, and the head does not continue to give way in that localized area.
3. Is there room to replace the alternator from above while the rear head is off? Alternator works good...so far. I'm thinking if the head and exhaust manifold is off, it might be easy to get to.
[EDIT] Yes, replacing alternator is EASY with the rear head removed.
4. Is there a "favorite" gasket set? I'd be very likely to buy the Fel-Pro HS9113PT1 Head Set unless there's a specific recommendation otherwise.
[EDIT] Used that Fel-Pro set. Worked great.
5. Anything else I should do while I'm in there and have it apart?
[EDIT] Timing belt/pulleys, serpentine belt, block heater, O2 sensor, and OIL PUMP DRIVE O-RING are all good candidates when the heads are off. Push enough coolant down the exhaust pipe, and you'll need a catalytic converter, too. REMOVE at least one of the exhaust valves, if they're as pitted as mine were, you'll want a valve job. DO NOT replace ONE head gasket. The rear gasket was actually leaking, the front gasket was damaged, would have leaked in a few thousand miles. Both gaskets failed in the same place. Common problem???
My questions are:
like 45min from below
