Got this code a few weeks ago and still havent figured it out yet. I know its a lean condition, guy at the auto store says bad O2. I know its not that, because the O2 is about a year old. Injectors came up as a possibility, fried O2 wires, and a vac leak. The wires look good on the O2, and I found what i thought to be 2 vac leaks, one at the EGR and one at the plastic thing on the left side of the plenum....where the FPR line is connected. I sealed both of those with RTV, but there still seems to be a leak. Intake manifold gaskets are also about a year old, but I have removed the plenum twice and changed out the lower intake once since then. All the gaskets checked out ok when I put it back together.
I can hear a leak....is it possible the head gasket could cause this? I know I had some really bad cooling issues in the past, and seem to have more of an oil leak than just the dist oring.
The exhaust is normal color, and ive sprayed Carb Cleaner everywhere looking for this bastard leak and cant find it. I checked all the lines and they all seem to look good. Are there any other vac lines under the plenum or behind the motor that I may be missing?
Have any other ideas of what could be going on?
I have reason to believe this is what is causing such a power loss in my motor...I pulled a best of 10.62@68mph in the 1/8 on friday
Also, when ideling, the rpms are up and down, and if it idles for more than a min or two, it kills itself.
