Ok i got water pump off ,,,,now the problem is i can only get 2 bolts to go back in to the water pump....other bolts will either not go in or go in at an angle
911...HELP
ok, the water pump housing only goes on "one way" and all other ways, not all 5 bolt holes will line up. So basically turn the pump until all 5 line up. There's also a metal locating "tab" on the outside of the perimeter of the pump, this should be pointing up.Brian
3400 SFI V6, 4T60e
