Originally posted by OldSkoolGP
AIR system (91-93 5spd cars)
Yah I didn't think 94-95 had the AIR, but I wasn't going to say anything.Originally posted by series8217No they didn't. I've taken both manifolds off both of the 94/95 cars I have seen in junkyards and none of them had any AIR tubes. The 96-97 used them on the rear manifolds, but those are different manifolds.Originally posted by OldSkoolGPOtherwise, the 94-95 3.4 DOHC with SFI did use the air pump on the automatics and the manifolds match your heads. That's another option you have.
I think it was an option on the automatic 91-95 cars tho, but I know it was standard on the 5-speeds and 96-97. But maybe you could get it with an auto if you ordered it that way (Maybe for dem californians
Originally posted by 91gtpI think it was an option on the automatic 91-95 cars tho, but I know it was standard on the 5-speeds and 96-97. But maybe you could get it with an auto if you ordered it that way (Maybe for dem californians
Come on Aaron. An option that does not change driveability, comfort, performance, or looks? Heck, shift solenoid "A" and the AIR system use the same pin. You think they make a second ECM so that you could order an automatic transmission with extra smog control if you wanted it? Jeezus. Where do you come up with this stuff?
Anyone got pics, or a complete 91-93 AIR setup for sale? I'm interested.
Basically, the system installed in the car with the engine in place including all the components. I can't tell where things are or where they go in the extreme close up shots posted earlier.Originally posted by series8217If you could get pics of each of the pipes (from above or below) for the manifolds, as well as the long pipe that goes between the two (?) and the location of the pump itself that'd be great. I don't know how much of it is visible from above. If its possible to get a top engine bay shot that shows some components that'd be great too.
Thanks.
