I looking in to buying a 93 z34 the outside of the car is perfect and so is the inside. but the woman said the motor was knocking its only got a 111,506 miles what could it be ??? shes asking 500 for the car is it worth a little motor work even if it could be somthing major
93 Lumina z34????
RE: 93 Lumina z34????
A knock is never good. Depends where it's coming from on what it is. If it sounds like lower end probably a main bearing. If you really want one and it is very clean, I'd say go for it, especially only 500 bux.
'93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
'06 Dodge Magnum SXT 3.5L -- My Daily Driver
Yeah, the 5-speeds are completely different animals compared to the autos.
For $500 you can make your money back or put in a new motor if you want to do the swap.
Yeah I say only invest the 500 if you plan on swapping the engine and the body would have to be prestine condition. Otherwise... drive it and listen. She may be stupid and actually be hearing the valves tick. Which seems to be normal. Listen to the exhaust too if it sounds irregular then yeah... run or plan on doing a swap.
Re: 93 Lumina z34????
You wouldn't happen to live in Windsor Ontario would you?Originally posted by crazycrakI looking in to buying a 93 z34 the outside of the car is perfect and so is the inside. but the woman said the motor was knocking its only got a 111,506 miles what could it be ??? shes asking 500 for the car is it worth a little motor work even if it could be somthing major
