No i haven't tried to unplug it. I could but it leaked while it was plugged in. Well not the EGR itself but some where in the line to the egr it does.
EGR Idle Question
I mean completely unbolt it. Reason to check egr passages.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
sounds like the egr solenoid may be stuck openOriginally posted by JasonZ34Unbolted the EGR and let it idle... it did so no problem, in fact the idle was high.
It was of course loud, I did not notice a vacuum nor could I see exhaust coming out of the passage.
the idle being high leads me to believe the intake side of the passage is clear. thats good.Originally posted by JasonZ34Unbolted the EGR and let it idle... it did so no problem, in fact the idle was high.
It was loud ....exhaust loud? If so that means the exhaust passage is clear. thats good.
Do you have anyway to scan pcm for live data?1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
If you turn egr back off. How does it run?1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
Switching back to the stock stat did not help. They tested the cat it was only heating to 400* Replaced the cat and still failed but much better.
Test Actual (allowed)
25mph test
HCppm 12 (114)
CO% .01 (.63)
NOxppm 526 (796)
RPM 2092 (2500)
CO+CO2% 15.1 (6.0 min)
15 mph test
HCppm 25 (117)
CO% .02 (.63)
NOxppm 976 (879)
RPM 1888 (2500)
I'm going to replace the oxygen sensor and try to clean out the egr pipe. That's all else the shop had suggested.
Spent about 340usd and 50usd in tests.
