what is this black box?
  • what is this black box?
    been looking at the engine compartment on my 3.4L GTP. found a black box at the front of the passenger side fender under the fuse box. what is this? the box has a crack in it close to the radiator fill neck. looks like water could get in this box if it was spilled.
    That is Most likely your Computer!
    If your talking about the small black rectangle on the Radiator itself, that
    is the Coolent sensor that tell you on the Dash that Coolent is Low.
    Hope this is correct and helps....P Peace
    94 Lumina Z34
    Moved Wife & Kids Out So I Could Have More Room To Park Z34 In Livingroom.
      thanks for the reply
      this is a fairly large plastic black box, not on the radiator. it has a crack in it close to the radiator fill neck. if water were to get in this box, am i SOL?
        RE: thanks for the reply
        If it looks like this...
        ...then its your ECM.
        [CENTER][COLOR=red][B]-Brad-[/B][/COLOR]
        [SIZE=10px][B][COLOR=blue]89 Mustang : Future 60V6 Power[/COLOR][/B][/SIZE]
        [SIZE=10px][COLOR=blue]Follow the build -> [URL]http://www.3x00swap.com/index.php?page=mustang-blog[/URL][/COLOR][/SIZE][/CENTER]
          thats a metal casing, but maybe the other end where the connectors are could have cracked. i have one of those from a 3.1 GP.
            Re: RE: thanks for the reply
            Is that the pcm that Blackbonbshell95 is looking for? For some kind of conversion write up you did.
            1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
            1972 3/4 ton 4X4 longbed, built 350, 400 auto, 6\" spring lift, 35\" AT/BFG\'s, dana 60 front axle, 14 bolt gm w/detroit locker 4.56 gears. My ricer smasher :)
              RE: Re: RE: thanks for the reply
              Yes.
                ohhh. me want bad!!! . i have all the parts except for that!!!
                02 GTP - 90* > Failboat
                [url]www.blackbombshell95.com[/url]
                  Where did you get that hood? Is it custom made??
                  1991 Pontiac Grand Prix GTP / 3.4 DOHC
