If you have access to a cutting torch (and knowledge of how to use it)
This is a simple yet very good tool. Will not slip off gear and plenty strong
enough to hold gear. I made it from a 1/2 piece of plate steel, 2 2' long 3/8 bolts, 2 lock washers and 2 nuts. The shank of a 3/8 bolt is a little to large to fit through the gear slots. As you can see by photos I had to file a step in the bolt. Simple to do with a drill to spin the bolt (after the bolt head has been cut off for correct lenth) useing a file slow file down till u get a good fit in gear slot. Bolt holes in plate are threaded. Nuts on back lock them in.
Tool will fit between strut tower and gear
