Here's my question thread continued
1) Oil Return: A large problem that I've heard of with this motor is the oil return system. Apparantly the pump throws too much at the top end and will actually drain the sump at high RPM. Anyone done anything to improve drainback? My machinist has actually suggested an external drainback system by plumbing a steel line through the cam carrier around the outside of the motor to provide another oil path to the sump. This would be accomplished by drilling and tapping a new passage through the head at a collection point, and shunting it off down through fittings and tubes appropriate for oil and high-temperature (read: SS tubing and hydraulic fittings)
Since some of the other "tweaks" involved restricting the flow of oil (which I don't really want to do) this seems to be a fairly simple and idiot-proof solution. Providing--of course--that it doesn't leak or punch through a water jacket
This of course will be done in addition to removing any accesssible casting flash in the stock galleries.
2) That goddamn distributor plug. Anyone have any ideas on how to seal that bastard but good? I was thinking of having a cork gasket cut to seal under the flange of the plug to the block... In addition to that stupid o-ring. While I can see silicone-gasket material working... It's too ghetto for me to consider other than a temp fix (yep, I'd done that, too) Furthermore, I'd just LOVE to figure out how to make it accessible WITHOUT removing the head. Any thoughts?
3) Related to the oil question... Bearing in mind that I haven't yet seen the inside of this motor, is there any benefit expected from either adding a crank-scraper (I think that's what they are called... Windage tray that strips the oil off the crank at high-speed to reduce frothing and rotating mass) or modifying the existing tray to do a similar job?
4) How efficient is the existing oil cooler? Given the slightly heavier than normal duty that this motor with endure (enjoy?
) would it be worth-while to replace it with a more conventional Air-to-Oil rad-type cooler? How about a separate coolant system with a self-contained pump and small secondary radiator? I guess the question is: How hot does the oil get in this motor
