The other day i replaced my Lower Intake Manifold and Fuel Pressure Regulator and I got rid of the coolant leak and the car starts right away now but now i have a sputter below like 3000. I have a 93 Z34 with the manual tranny. The sputer is most noticeable in first gear but can be felt in second too. When it sputters it acts like my bike when i am running out of gas or if its not warmed up yet in the morning. When i take off it will sputter for about two seconds before it winds up. Once the rpms get above about 3500 it will run smooth again but im not sure if it has all the power it should. I am wondering what i should check first. Since i did disconnect the fuel lines and pull the fuel rail i am wondering
1) could i have gotten dirt or something in the fuel lines?
2) could one of the lines not be connected correctly?
3) could i have gotten an injector messed up or reinstalled incorrectly in the process?
4) would a vacum leak cause such behavior?
Thats what i could come up with. Where do you guys think i should start or is there something else i should look at? The fuel filter is pretty new, same with the iac, and i just installed the 60v6 chip.
Edit: The other day it gave a big puff of smoke at startup for the first time ever...hasnt really done it since though
