Well, for some reason, my 93 GTP is stalling again... Some facts: it only happens at low speed and low idle. For instance, when I'm pulling into a driveway/parking lot, it stalls after making it into the lot. And this may (or may not) be a seperate problem, but it *sometimes* stalls when slowing down from >50mph. I was kinda thinking that could be a seperate problem with the torque converter lockup. Also, I've got a code 32 that comes and goes, but only after it gets warm and is driven for a long time. Replaced the EGR and cleaned the passages to no avail, so I think it might be another sensor that detects the EGR's opening. That could be related to my stalling problem. As well, it has a "random miss" at idle. I just don't even know where to start
Ido have ALDL software
AAAAAAAH! Phantom stalling again!
With all that you said, check your EGR harness first, if bad check/replace the MAP sensor. The MAP sensor does survey EGR operation via induced vaccum signal change by the operation of the EGR. A tune up is a good idea after, get some quality wires.Lorenzo
GOOD NEWS! I think I fixed the Code 32 problem! And possibly the stalling! I found several plug wires with gouges and burns on them, and one wasn't seating properly... I replaced that, and no more random miss at idle, and I haven't been able to get it to set a 32. Usually it shows up after a 4 mile drive, but so far so good! If this is the case, wierd that spark plug wires could cause an EGR code.........Okay now, that's enough of that.
For those of us not blessed with living at home and don't have money to throw at the car all the time usually clean the pintle, and spring on the IAC with carb cleaner, then clean the bore the pintle seats in. Just make sure the O-ring is still around it when putting it back in to keep a good seal.Originally posted by AaronMost 3.4s do it, you are not alone. I replaced my IAC valve, and it no longer stalls, but will still dip low every now and then. I'd suggest change your IAC, couldn't hurt, might help
More facts from ALDL: (some of this doesn't mean anything to me, so maybe it will to you) integrator: ~128, rich/lean ~200 (and climbing), spark advance, 49.4, desired idle ~700, actual ~800rpm, IAC *GOES TO ZERO* after being idling a while. Does this suggest a vacuum leak? MAP .38-.43 (which if I calculate right, = 11.4-12.9" Hg, while my mechanical gauge shows 13-14"... hmmm), TPS range .50 - 4.43. Any ideas?Okay now, that's enough of that.
Haven't changed it, and I don't plan on it unless I can say with 90% certainty that is what it is. I don't know the exact point the car stalled (it's so quiet anyways), but it was probably shortly after coming down a slight hill, so I probably let off the gas a little. One more thing to add - the Injector time hovers around 1-2 (ms?) at idle, does that seem out of line?Originally posted by Lyle's GTPI'm not sure but I don't think you IAC should drop to zero. Did you change it. Also when your car stalled were you applying constant power while cruising, or did you let off the gas slightly? One more thing, check all your connections.
LyleOkay now, that's enough of that.
