Originally posted by HayesPerformance
View Post
if you chip it you can run a 2bar or 3bar if your chip is setup for turbo otherwise run it as is and if you get a code use a check valve.
Oil feed is from the oil pressure sensor. and return you have to drill the pan and add a bung for the oil dump. the oil dump must be toward the top of the pan above the oil level cause the oil return is gravity fed and must drain freely back from the turbo.
