obd1 to obd2 conversion
  • IsaacHayes
    replied
    Or is it we are getting confused with the 24x crank sensor? That it's not read above 2500 RPM? Or is it both?
    replied
    All SFI systems revert to MPFI after about 2500 RPM, or so I have been lead to understand by folks alot smarter than me.
    The computer simply can't keep up with individual cylinders after that, so it's really not an issue.
    As far as which system is best that may be a personal preference, but OBD-1 is probably the easiest and least expensive to tune.
    sounds like what i've been told... i have to wonder how we could test it? and at raising speeds, the exact opening time for the injector becomes less and less important...
  • asylummotorsports
    replied
  • OldSkoolGP
    replied
    AFAIK, OBD-II stays in SFI mode throughout the rev band. I can't think of any other exsplanation where with OBD-I my car had a blip of reduced power between 5-6K, and with OBD-II I now have a surge of power between 5-6K. 5-7K is now the strongest part of my rev band where before my power was almost gone over 6K.
    replied
    i wonder if disconnecting the cam sensor does anything other than reverting to MPFI? possibly the PCM adds more fuel, takes out timing to "compensate"?
    but i have no problems with idle quality, then again, i don't have 4 valves per cylinder, so i wouldn't be penalized so much at low RPMs for airflow/turbulence
  • IsaacHayes
    replied
    yeah I thought it reverted to MPFI above a certain RPM too. It would make sense that the valves opening so fast that the higher the RPM the less it would matter.
    Someone should dyno their car then disconnect the cam sensor so it goes to batch fire mode and see what happens. Hmm I might try that on my car just for the hell of it and see if I can't get the MPFI rumble at idle they have... LOL
    But for idle quality and part throttle cruising at low RPMs power I have to agree SFI will win there.
    replied
    i'm used to OHV motors... can't argue about what i don't know about...
    and i really don't trust dynos down to those kind of numbers... not to mention, doesn't OBD2 SFI revert to MPFI above a certain RPM(like 3000-3500)? i know all of the obd1 and 1.5 systems do...
  • OldSkoolGP
    replied
    while thats true, it only really helps with emissions
    A more efficient burn only helps with emissions? Horsepower is a measure of an engine's efficiency. If you can get more out of an engine putting the same amount of fuel and oxygen into it, that is the definitoin of more efficient. If it is reducing emissions, it is because the combustion is more complete. How is that a bad thing?
    you could dyno the same car twice, with the same tune, the only difference being running in a SFI mode, the other being MPFI, and the amount of power/torque will be exactly the same within the tolerance of how accurate the dyno is.
    Uh, did that. 8 more WHP on a stock OBD-II tune and no other mods, vs. OBD-I with some tuning. You want to put that down to dyno inaccuracy? Tuned it a little more on the dyno, got another 2WHP out of it, no other changes.
    it obviously doesn't help idle quality, i can vouch for that.
    Try owning a DOHC and getting a smooth idle out of it. Mine idles smoother with OBD-II, and I can vouch for that.
    replied
    while thats true, it only really helps with emissions. you could dyno the same car twice, with the same tune, the only difference being running in a SFI mode, the other being MPFI, and the amount of power/torque will be exactly the same within the tolerance of how accurate the dyno is. it obviously doesn't help idle quality, i can vouch for that.
  • OldSkoolGP
    replied
    I'm not gonna sit here and debate which is better. That's for each of us to decide. You got your reasons and I got mine. But I'm not let anyone get away with saying that PFI is better than SFI because that is ridiculous. With PFI, all the injectors fire at the same time. With SFI, the injectors fire when the intake valve opens. If your fuel isn't puddling on your intake valve and staying atomized from injector to combustion chamber, you get a better burn, pure and simple.
    replied
    it usually only takes 2 or 3 tries to get the VE right, then the spark is pretty easy as well, just look for knocks, and reduce it there by .5 degrees at a time until it disappears. maybe another 4 or 5 there. obviously bad sensors could cause issues, but in general it isn't worth it to me to spend the initial investment on something i'm only going to use maybe 10 times per setup.
  • IsaacHayes
    replied
    I haven't looked at the prices lately. Depending on how irritating it is swaping chips, I would probably get the emulator, tune, then once I had a decent tune that was drivable, sell the emulator and swap chips when I get a more precise tune or after a small mod.
    I guess it depends how far off the LQ1 tune is from stock, or how radical of an engine swap you have if it's worth the convince.
    replied
    i'll stick with the 90 it would cost me for the burner + chip, rather than the what 170 for the emulator? still cheaper than obd2, and faster too.
  • IsaacHayes
    replied
    Or u can use the moates emulator so you don't have to swap chips........
    replied
    Originally posted by OldSkoolGP View Post
    Well, everyone always forgets that I was the first or second one to (insert DOHC related modification here),
    5 speed swap? Oh yeah, that was me... Tapered TB, oh yeah, me again.
