what is needed for dual throttlebody intake?
  • #31
    Meh, I'm used to no aftermarket anymore... Aftermarket is overrated TBH.
    Off topic (slightly). Ben asked me to try to think of a name and slogan for his company years ago before it officially came to be. One slogan we came up with was "Because stock sucks!" lol.
    • #32
      this thread isnt about what is better for what app, its what is necessary for 2. if you are trying to prove why one is easier/better than 2, your wasting your time because im just asking how to make the OBDI MPFI computer able to handle 2 throttlebodys.
      regardless of when where why or how, id like to know what is required to make the computer able to handle the dual tb's.
      to be fair i never said jack about the car or trans, for all you know it could be an jacked up LQ1 mounted to a 94+ T-56...
      • #33
        basically, there is not much difference required (electronically) for it to run correctly on an OBD1 computer...
        • #34
          how is there not much difference? wouldnt the values need halfed? or would it just require the person doing the tuning to know & account for the dual tb's, & to use only one map sensor & assume both values are equal?
          • #35
            if making a common-plenum design, than MAP sensor would be no issue at all.
            making the TBs feed seperate banks with no connection between: that requires some trickery...
            • #36
              im referring to no connection between, as straight of a line from air filter to intake valve as possible-no 90* angles, 120* max.
              • #37
                MSPaint...
                theres LOTS of ways to go about it, which EXACT one do you have in mind?
                • #38
                  ill draw something up a little later
                  • #39
                    Porshe trannies are Borg Warner. You should remember them, they make the T-5 "World Class" (more like world class piece of shit.) Major case deflection failure problems.
                    also, I talked to the makers of Raptor Transmissions..http://www.transmissioncenter.net/
                    They make a bullet proof 700r4, I've bought a few from them in the variing stages that they have available. We put a full raptor in our 1990 Ford Explorer 4.0L v-6 blown and nos. yes 4x4 and 4-door, it did 12.s. But we couldn't keep a ford A4LD together. every 3-4 passes and boom, another tranny dead.
                    Anyway, i talked to them about building a 4T65e with a northstar case, tranny in the Olds intrigue, because it would bolt up to my dreamer of a project, a 4.0L Aurora powered Achieva. The told me i would have better luck with them building a 4T80, that the 4T65e couldn't or wouldn't hold up to the toque and power output of the modded V-8. They said a 4t65e, built, could take around 450 hp, but it ain't going to live long, and under race conditions they wouldn't chance depending on it, maybe 6 passes and it's dead.
                    Now, since Getrag 284's are hard to find and I really want the consistency of an automatic, I'm kinda screwed. the motor and engine assembly is 6 inchs wider then my front end! Not the removable sub-frames, the main box steel that runs under and is apart of the strut towers. Also, my master cylinder needs to be moved 8 inchs to left of car to clear the head. Maybe some kind of linkage?
                    • #40
                      284's hard to find? Pssshh, I'm 2 of 2 when it comes to GM vehicles in my drive
                      I know about the A4LD. It has a bad rap on TRS. The Ranger guys hate it. Raptor transmissions huh? Fords SVT team made an off-road truck named the Raptor. It's really ugly if you ask me, but I would ride in it.
                      • #41
                        ECM isn't an issue. Even with separate plenums, you can still tie the 2 together with a small vacuum line to feed a single MAP sensor. A single TPS would be possible as well by just connecting the throttle plates together. About the only thing I could see an issue with would possibly be the IAC, but again, you could create a standalone IAC enclosure and feed both plenums off of a single IAC.
                        See a drawing I did almost 2 yrs ago...
                        • #42
                          what would be needed to be done with the iac & where is it located at in a stock configuration?
                          • #43
                            on the 3x00s its integrated with the TBs, so i'd look around there on a 3.4. since the 95-earlier ones have the TB cast into the intake itself, its a little more confusing to me....
                            • #44
                              Here are some shots of an IAC adapter me and another guy designed, wow, I guess 3 years ago. Give you an idea of what to do. http://60degreev6.com/forum/gallery/...p?c=17&userid=
                              And here is a thread (pics don't work ) discussing IAC adapters. http://60degreev6.com/forum/f109/mak...on-3500-t29285
                              • #45
                                I've read this thread start to end a few times and I'm still completely lost on what is to be gained from having two small throttle bodies. Seems like a huge pain in the ass. Wouldn't it just be easier to bore out the original and put a bigger plate on the existing single?
                                1991 Pontiac Grand Prix GTP / 3.4 DOHC
