Hi to all,
Just wondering if i removed the Catalitic converter ( i thaik that is what it is called ) and then just spliced in a straight piece of exhaust pipe, would it give me better Gas Milage and maybe a little more pep? I live in Louisians and they don't require the converter to pass any kind of smog test.
Would it change any kind of critical backpressure or hurt anything as the OXYGEN SENSOR ( THAT I REPLACED ALSO) is before the cat.
I am just trying to figure out how to get better Gas milage as i have changed every kind of sensor i can think of ...all AC/DELCO and Timing Belt with all Pullies, and now my Gas Milage SUCKS...I had a shop check the Timing when i was done and it is correct and right on the money. Car runs like a bat out of Hell...just worse Gas Milage...since i did Lower intake Gasket & all Sensors while it was apart.
any thoughts?????
any thoughts?????
