96 Beretta Project
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
awesome car and build man!
I recommend TCI or hughes also if they build TQs for 4t60s (which I don't know for sure either way). My powerglide is a TCI, and I'm running a hughes tq in the dragster and camaro. Can't think of any issues i've had with either company.You may or may not know 10 times what i do.
This is what I got back from Tripple Edge. 6 days after I contacted him.Originally posted by torq455 View Post
I also contacted Precision Industries direct....Hi Jonathan,
Thanks for your interest in using us for a torque converter. I dont have a good suggestion for you off hand as I dont have much experience with your setup other than stock applications or stock and modified 3800 engines which will definately behave different. The problem with most stall rpm ratings is they are only for a stock engine in a given application and there is a world more to the true stall speed. Stock ratings are rarely ever accurate, nor are most aftermarket converters unless tested on a specific application. A 3200 rated converter could stall 2500 in one car and 3500 in the next. For custom built torque converters we use Precision Industries and they will build the converter to match the engine specs and desired stall speed, as well as to match the power adder being used if any. Not all converters are created equal and every combo and power adder will make the converter behave different. A 245mm converter for a fwd application is pretty universal across the board so there really isnt anything model specific. The Precision Industries torque converters use their own proprietary lockup clutch material that is fully compatible with the older on/off style tcc systems and also work fine with newer pwm tcc systems.
David Norris
Email: Dave@tripleedgeperformance.com
Website: www.tripleedgeperformance.com
I can only Image what Tripple Edge will charge me if PI is quoting $808 since they said PI's would custom make one, so I can only imagine when he sends them my info they will come back with the same converter. I really dont need the CNC Billet Steel front cover.From: jack@converter.com [mailto:jack@converter.com]
Sent: Friday, October 14, 2011 10:39 AM
To: jpchmura@att.net
Subject: RE: Contact Us Form
The converter we make for your car is a 9.5" Vigilante with a CNC Billet Steel front cover, heavy duty lockup, all furnace brazed and comes with a 5 Year Warranty. The converter sells for $808.04 and the build time is around 5-7 working days.
800-649-7866
I'll see what TCI Auto has to say. But right now I'm liking the responce and info RevMax has given me.Last edited by 3400-95-Modified; 10-24-2011, 12:06 PM.
I have one 4T65E and one 4T65E HD. I forgot that's what Triple Edge mainly works with. Me bad.Andy
They share the same converter though, I can use my 245mm converter on a 65eHD without a problem... The only difference would be what motor I'm working with, and aparently he is used to doing the 3800's and is not used to what power a 3400 can make with my mods.
It's a whole different powerband. Therefore, different tranny shift tuning is required.Andy
I'll be at SEMA next week... I could talk to some companies if you wanted to send me a spec sheet.You may or may not know 10 times what i do.
This is what I've been telling converter companies right now.
RevMax did ask for an estimate HP chart and I gave them what Ben sent me recently. If you do a MPH/weight to HP calculator you get 317 too... kinda funny... I did my 107 when it was 3125-3150lbs IIRC... my lightest before the brakes was 3040lbs and that was the 13.996@98.06 that I got, that put me at 235.59 hp estimated... I can almost accept that too since I did NOT have ported heads and such then, and also had a very loose timing Chain and the stock lifters.Converter Company,
I'm looking to get a new converter for my setup and I'm trying to find the best option. I'm currently running a PDQ converter but I'm not that impressed with it. I've been told its tweaked to around 3195 stall yet when I leave the line I'm at 3800RPM + and on my shifts from 1st to 2nd I'll go from 6500 rpm down to 4818 rpm when I'm not spraying nitrous… When I'm spraying I have an RPM range of 5100-6700 that's it, after 1st gear the lowest RPM is 5100 after the shift is complete. My final drive gear ratios at the wheel are 10.71:1 for first and 5.75:1 for second and 3.69:1 for third. If you ask me the RPM drop doesn't seem like it's enough for a converter that should be stalling around 3200. This is in a 1996 Beretta with a modified motor and 4t60e transmission running on a 100 shot of nitrous. Cam specs are 216/240@.050 duration .517/.568 lift 112LSA this is on a 60 degree V6 engine 3.4L displacement with a 3.5L top end on it. I've currently put down a 12.67@107 last year but the tires were spinning so much I know it can be better.
With my gear ratio and tire size assuming zero slip and immediate shift times if I were to shift at 6,400 2nd gear would take over at 3,470. I typically complete my shift around 6700 so I would like to see somewhere in the range of 4200-4500 after the shift… if that's at all possible… I'm honestly not sure. Right now at a 6700 shift I end up at 5100 rpm, and on a second to third at 6600rpm shift I end up at 5200rpm.
I was wondering if you could make anything for my application, and what it would cost. My converter is a 10" Diameter, 27 Spline, .824" pilot, 9 1/2" Bolt Circle, it also has a TCC lockup clutch that I would like to keep intact. If you like to start with cores first, a FAFB converter for a 4t60e FWD application is a 2795 stall to start, and it comes with a lockup clutch which I want to have since the car is driven long distances at times.
Let me know if there is anything you can do for me and what this would run me.
Jonathan Chmura
These are 500 RPM increment starting at 2k and ending at 7k.
N/A: 77, 103, 123, 148, 177, 207, 232, 251, 262, 263, 259
100 shot: 166, 190, 209, 232, 259, 287, 312, 317, 293, 295, 290Last edited by 3400-95-Modified; 10-26-2011, 01:33 PM.
Thanks, its been a project getting it to where it is now... and still is a project... LOL
Yeah, same here. I started this turbo build of mine 3 years ago. Lots of time working out the bugs resulting from custom engineering stuff.Originally posted by 3400-95-Modified View PostThanks, its been a project getting it to where it is now... and still is a project... LOL
Once I get the car running near flawlessly w/ a tune superior to factory....I'll be starting the mods for high boost. Even considered drilling out the plenum barb fittings for air tight flared fittings. I plumbed stainless steel vac lines and love it. But all in due time. I got to work the manual in some first. Get the clutch broke in and tweek the PCM.
I finally got the heated garage ready for winter. Now I can work in warmth while it snows.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
I have heat in my garage but its not insulated so I need to warm it up before I head out there... Kinda sucks, I wanted to get some insulation in it this summer and fall, but time just hasn't permitted that to happen... same with funds... Oh well... If I get down time in the winter I can always throw some stuff up.
Responce from TCIauto's contact website....
Sent PATC an e-mail, but it's looking like RevMax has the best price and has responded as the most educated so far.We don’t do anything with transaxles unfortunately. You will want to contact PATC 1-888-877-1008 or www.transmissioncenter.net
- Don Mudrich
TCI Email & Live Chat Sales/Technical Support
TCI Automotive
151 Industrial Rd
Ashland, MS, USA 38603
1-901-375-3483 (my direct line @ Comp Cams) 8 AM to 5 PM CST Monday thru Friday
1-888-776-9824 (TCI main line)
1-662-224-8255 (TCI fax line)
Leading provider of high performance automatic transmissions, torque converters and drivetrain components for race, street/strip, hot rod, street rod and towing.
dmudrich@tciauto.com
*If you are replying back to this email, please retain all previous text originally sent.
Sent: Monday, October 24, 2011 11:06 AM
To: tech2
Subject: TCI Tech Support - Jonathan Chmura
Message sent to TCI Tech Support
Sender Name: Jonathan Chmura
Email: jpchmura@att.net
Message: I’m looking to get a new torque converter for my setup and I’m trying to find the best option. I’m currently running a PDQ converter but I’m not that impressed with it. I’ve been told its tweaked to around 3195 stall yet when I leave the line I’m at 3800RPM + and on my shifts from 1st to 2nd I’ll go from 6500 rpm down to 4818 rpm when I’m not spraying… When I’m spraying I have an RPM range of 5100-6700 that’s it. My final drive gear ratios are 10.71:1 for first and 5.75:1 for second. If you ask me the RPM drop doesn’t seem like it’s enough for a converter that should be stalling around 3200. This is in a 1996 Beretta with a heavily modified motor 4t60e transmission running on a 100 shot of nitrous. Cam specs are 216/240@.050 duration .517/.568 lift 112LSA this is on a 60 degree V6 engine 3.4L displacement with a 3.5L top end on it. I’ve currently put down a 12.67@107 last year but the tires were spinning so much I know it can be better. I was wondering if you could make anything for my application, I know you list OEM Replacements for the 4t60e and 4t65e, and what it would cost. My converter is a 10" Diameter, 27 Spline, .824" pilot, 9 1/2" Bolt Circle, it also has a TCC lockup clutch that I would like to keep intact. If you like to start with cores first, a FAFB converter for a 4t60e FWD application is a 2795 stall to start, and it comes with the lockup clutch I want to have. Let me know if there is anything you can do for me and what this would run me. Jonathan ChmuraLast edited by 3400-95-Modified; 10-27-2011, 03:31 PM.
Sometimes I found a brisk chill motivated me to get the job done quicker. lolOriginally posted by 3400-95-Modified View PostI have heat in my garage but its not insulated so I need to warm it up before I head out there... Kinda sucks, I wanted to get some insulation in it this summer and fall, but time just hasn't permitted that to happen... same with funds... Oh well... If I get down time in the winter I can always throw some stuff up.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
