Originally posted by unchained01
									View Post
96 Beretta Project
 Yeah i was going to have two posts go down to where the stock coil bracket mounts.
 No clue, I thought I got grease on all of them but who knows maybe I missed it or something.
 So slight dilemma... I guess you could call it. Spoke with the guy who got me all my direct port stuff and he informed me that having all the supply lines be equal length really isnt that necessary... SO the question is do I re-do the lines to make them straighter and more direct, or do I just leave them the way they are because they look sweet...
 I also made my coil bracket last night so that should be all set.
 I would keep them equal length.
 The coil pack bracket turned out great, nice work.2000 Grand Am GT
 2011 Chevy Impala
 That's what I was leaning toward, they are all 8.25" long and then I was going to ensure that the lines leaving the solenoids were also the same length to each block... I want to eliminate any oddness of the distribution and I think this is the best way to do so. Obviously there is no way to make the fuel and Nitrous delivery happen at exactly the same time unless I figure out how fast the Nitrous flows at 950 psi vs the fuel at 63 psi and then get a ratio and shorten that supply system to compensate... LOL way too much if you ask me.Originally posted by onefastV6 View PostI would keep them equal length.
 I'll just put a fuel purge switch on it and hold the throttle open a tad and tap the switch to purge the fuel side of things. I think the slight lean spot I saw on my last runs with my setup were due to the supply line for the fuel being quite long and near some heat so it probably would evaporate in the line leaving air, and then of course you purge the Nitrous side of things so that is there and ready to go.
 They look great just the way they are I wouldn't change a thing.
 Coil bracket fits under the hood...
 Yes I am... It's so nice to have the welder so I can just create something when I need it and I can get good welds with it too. Worst part is I have no material to work with so I have to think about it and then go buy stuff... I need to just order a bunch of various sections just to have some things on hand since I know I will be using it often.Originally posted by ForcedFirebird View PostEnjoying the new welder, I see
 Yeah, I went out a bought a bunch of steel items when I got my Tig.
 Washers, rods, plates, tubes, ........all the small items that are inexpensive. I just need to source the bulk of most projects.
 I often looked at my wifes steel kitchen ware thinking Hmmmm, nah. Not worth the ass whoopin.
 There is a ton of steel all around ready to be used. But then I do live in steel city, Pittsburgh full of Rust and Funeral Homes. Ugggh
 Recently I cut all kinds of scrap off a dead washer and 2 steel shelves. The washer made a great source for 2'x2' thin steel plate.Last edited by TGP37; 03-09-2013, 09:46 AM.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
 Just ordered a set of Teflon 350 cam bearings... Hopefully these last this time. The ones I have look decent but there is one spot on one where it looks like it took too much pressure and started to flake apart... I can't understand why though, the rest look fine. If this teflon set gives me any issues then I think I'll have to have the block checked and ensure the cam journals are straight.
 Timing chain was dead though... Gears looked fine.
 You could hear this outside the vehicle when it would idle... Not a whole lot of extra play in the cam to the crank, but just NOISY!
 Time to get them coated for real
 Motor coming apart.
 Been a while since it's been like this... over 2yrs since I redid the bearings in the motor at least...
 I love pictures. lol. Did you just use some spray can "sealer" on the headers before?14.63@92.9 -Full LX9 with CAI, 65MM TB, 2.5in DP, Borla Cat-Back, Crappy tires, Quick tune (Dyno Soon)
 No, it was actually a DIY ceramic coating, but unfortunately I don't have a oven large enough to bake them so I relied on the baking when the vehicle is run, which is a bit unreliable... I also tried to seal coat the front one and that burnt off because it wasn't quite dry enough. If I had the oven to do it in I think they would have baked on fine and lasted but engine heat is just too inconsistent and sometimes too hot.
 I want to coat the hotside on the Fiero, but right now, it's not in the budget or timeframe...
 what all are you going to do to the engine while you have it out?"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
