also DAMN dave..... how you kill a rear end with a V6? the V8 guys will not be pleased. launching with slicks?
TKO is easier, and probably cheaper... did you make any passes on it?
2 but nothing to write home about, shift cable was mis-adjusted so they were pretty slow.
oh and Crank case pressure going down the track at WOT stays about 2kpa above the baseline. It's good to know that there isn't any excessive pressure, i'd still like more of a vacuum though.
I see them used for about 1K all the time, and IIRC, it's based on a T5, which should make it more of a bolt in and go deal.
I decided on a t56 mostly because I already had it. So far the majority of cost in getting it to work has been buying the clutch and flywheel. The sbc adapter is only $70 iirc.
At least it looks like it's a set of spiders and nothing real expensive and a pain to set up like a ring and pinion.
I might have to re-think my rear end choice after watching those vids.
96' beretta - stock 3400 with 3500 top swap with a 5 speed and thats about it.. Oh and a spec stg 4 clutch that slips when i turn the boost up:owneddance:
06' dodge ram on air suspension with a basic 3link set up. sold :dead:
LOL You don't have to post that thing in every "quick" V6 F-body thread... just start your own thread.
esp considering it has a 3800... lame!
