Help ID Engine
  • Help ID Engine
    Greetings and salutations. I come in peace and I bring you good tidings.
    I am working on a swap. I have a 69 or so MGB with a GM V6 engine.
    I need help in identifying this engine. I am hoping it's a 3.4.
    What information can I provide you Guys to help me? The only number I can readily see is 061L / 3
    Here are some pics
    I hope to have the engine and trans out this weekend to hopefully start the rebuild if it's a 3.4
    i don't suppose you could find the VIN number on the block?
      Hey, that was fast, thanks Man. Where do I find this number?
        it SHOULD be near the starter.
        if i had to venture a guess though, based on the numbers from the side of the block, it sounds like a 2.8, and an old one at that...
          if you manage to find a string of numbers, try searching them in here:
          Login kedalam situs MEME4D adalah langkah paling tepat untuk mengenal system taruhan online toto resmi terkini yang semakin canggih, adaptif, serta ramah lingkungan untuk semua kalangan pemain.
          F-body 3.4 motors had block casting numbers of 11018608 and 24504089.
            I see. It is an old conversion so it could very well be an old type.
            The conversion kit can use up to the 3.4L engine (60 degrees), is this still a decent engine with decent power or should I instead look for a 3.4 which is the highest horsepower 60%
              for a simple upgrade, yes a 3.4 from either a 93-95 camaro or firebird would be your best bet.
