Help my idle seems to have gone nuts, at first it ran just fine then on a run down the coast the idle suddenly decided to run at 1200-1500, I replaced the IAC and MAP sensors as they were some of the only ones that had not been replaced from the original 95 firebird donor car but to no avail.
I started the car today and from cold idle was at 2000, and would not reduce then all of a sudden the idle shot up to 2700 so I turned the car off, on restart it was still in the 1500+ range.
Yikes what's the scoop here and what can I look at?????????
by the way this is a new long block with ancillaries from a donor 95 3.4 V6 out of a firebird and it is in my 1973 MGB roadster
