It is an LX9 "3500", which is a 3.5L variant of the 60 degree Chevy V6. This particular one came from a 2005 Chevrolet Malibu, with 116k miles according to LKQ. This 3.5, unlike the later ones, is based on the 3.4L "3400" LA1, with updated head and intake designs, and gaskets that won't fail like the earlier Chevy engines. The later 3.5s are a smaller displacement version of the 3.9L, so they have variable valve timing and E85 capability, which are very difficult to make work in older cars.
This engine is not really plug-and-play. I have had to order the 3500 swap kit and 1997 PCM from Milzy Motorsports. Mike spent almost two hours on the phone with me, ironing out all the details of this swap, making sure the computer would be programmed how I wanted it, doing up a custom throttle body, and all that. He also said that, if there were interest in the A-body community, he might put together a swap kit specifically for A-bodies, using my car as the prototype!
Particulars of swapping this engine into my car, in no particular order:
I'm sure more will come up once I yank the stock engine and start transferring over parts. Look for that in the coming days.
- I will not be using the LX9 upper intake. It is wholly incompatible with my car. It lacks three vacuum nipples I need, for the HVAC, MAP sensor, and vacuum modulator for the transmission. I will be using an LG8 "3100" upper, which is what Oklahoma used in his top end swap.
- Since I'm not using the 3500 upper, I will not be using three parts from the swap kit: throttle body adapter, coil pack adapters, and MAP adapter pigtail.
- I'm also using an LG8 front valve cover I got from a yard off of a Malibu, which has a GM Goodwrench crate motor sticker on it proclaiming it to be a 3.1L.
- I will have to use my stock exhaust, since the downpipe is routed differently than any other car/engine.
- The throttle body will be from an LA1, modified by Mike to (hopefully) be plug-and-play with my stock cables.
- I will be using my stock fuel rail with 24 pound ACCEL injectors that are the same "fat" design as my stock injectors. The newer "thin" injectors have different connectors, and they are too tall to fit under my stock rail.
