'92 LUMINA Z34 - front right wheel stuck
  • '92 LUMINA Z34 - front right wheel stuck
    Don't know where this should go but here goes...
    Going to check out a 92 Lumina Z34 with a right wheel
    that won't turn. Dude selling the car said his GF
    was driving it then heard a clicking that turned
    to a clunking then it seized up. I'm thinking stuck
    caliper but could be an axle issue. Anyone care to
    share their knowledge or experience?
    Take a look at it. It probably is a CV axle if it was making that noise, unless the wheel bearing failed. But if it won't turn then it's probably the axle bound up. I don't think a broke tie rod end would cause the wheel to click like that....
    [/SIZE]
      car's only got 100K but I believe
      you're right. hope it's a brake or
      bearing issue though.
        could easily be a caliper abutment bolt that came out and now the caliper is stuck in the wheel. try it in reverse. or the CV.
          Ah yeah wheel being stuck as in not spinning. I was thinking turning...
          [/SIZE]
            id try jacking the car up and spinning the wheels in neutral. if the other side spins alright, its not a tranny or diff issue.
            id say stuck caliper. ive never seen a hub assembly seize up before, they ususaly just get real loose. axles usualy dont bind up, they just blow apart.
            [img]http://memimage.cardomain.net/member_images/10/web/2938000-2938999/2938592_1_full.jpg[/img]
              Was really hot on this car until
              seeing it in person. Horrendous!
              Looks as though it never saw
              the inside of a garage. Lots of
              work inside and out. Dude said
              100k on the phone then come
              to find out 114k.
              as for the front wheel, I did not
              even pull it. had a quick look and
              nothing seemed out of the ordinary.
              caliper was fine and bolted down
              axle looked dandy so this one is
              a mystery.
              the only plus is brand new tires
              but he wants a cool grand. sad to
              say he should have let the car go
              before blowing $$$ on tires.
              when taken care of these cars are
              sharp, in fact there's a fine example
              of one on ebay at $3k right now
              and here's the POS I saw this morning...
                that steering wheel never gets smaller....
                Lorenzo
                  I wish I had Z34 Luimna like that one even a Euro coupe is nice.
                    i had the exact same problem once.
                    front right caliper came off, turns out a very important bolt didn't get tightened up after I replaced the brake pads.
                    [SIGPIC][/SIGPIC]
                    1993 Cutlass Supreme SL Coupe - 3.1 MPFI
                    Performance:
                    -Cone Air Filter. that's it. :p
