’95 BerettaZ26 3.1
Ok here’s what led up to this problem of mine. For a couple weeks the ignition cylinder was getting a bit sticky and the starter wouldn’t fully engage. Now what I mean by that is that it would click (but not like a dead battery) but sometimes it would take a second or two for it to spin. Now I was thinking the brushes are bad but my thoughts have been swayed. Well needless to say I got pissed and started banging up and down on the tilt steering. I know dumb move, but now it starts (w/ the same problem mind you) and I can’t shut the SOB off now!!! It’s stuck in the run position. I have to pull a fuse and disconnect the battery to emulate it in the off position. And obviously it won’t go into AUX either. Anyone ever come across a problem like this? If so Please send me some insight!!! Friends keep telling me that theres wires on the cylinder. Nope sorry!!! Not that I've seen.
P.S. any tricks on how to get the retaining clip back on the lock plate on the column? Any trick that shave any time off my three hour curse and throw $#@T fest
As always thank you!
Respectfully,
Phil
Respectfully,
Phil
